Why does Compress not allow the opt
Why does Compress not allow the option of using SA-182 F22 Class 1 Long Weld Neck Flanges as a material choice?
RE: Why does Compress not allow the opt
pvrerate, I don't have the most current references at hand, but it may be because Cl 1 is not listed in B16.5.
Mike
Thanks so much. You are correct. In the past we have only used this material for Appendix 2 flanges that had a design temperature of 1015F to get a slightly higher allowable.
