Help in calculating fastener flexibility values in fastener joints
Hello folks,
Firstly, this is mainly a FEM & specifically Nastran question but since it is almost used exclusively used in Aerospace industry (?), I thought it would be more appropriate here rather in the FEM sub-section of the forum. I can move there if deemed necessary.
I have a question on calculating fastener shear flexibility values for Nastran CBUSH element using Huth equation under a double shear setup.
I have created an image which hopefully will convey my question clearly.
So essentially my question is, does the industry use:
1. n=1 (i.e. single shear condition) for each CBUSH element and consider thickness of one of the plates as 't/2' during calculation of fastener shear flexibility using Huth equation?
2. n=2 in Huth equation for each CBUSH element?
Thx,
- B
Thx,
- B
RE: Help in calculating fastener flexibility values in fastener joints
Just wanted to cast a wider net on my original post like which way is a double shear fastener FE modelled in Industry. As two single shear spring elements? Or is there a better way?
Thx,
- B
