Associative Centre of Gravity / Centre of Mass of a Sketch/Curves
I'm trying to get an associative CoG/CoM of a Sketch/Curve, I can get a non-associative CoG/CoM just fine, likewise an associative CoG/CoM with a body.
For context, I'm hoping to use the individual CoG/CoM's of a set of sketches to then align them along their CoG/CoM axis - I'm aware this will need some work around method as just using the CoG/CoM to do so is likely to be a circular reference. The method must be parametric & provide a set of sketches/curves which can then be used to create a sweep.
Thanks in advance,
Liam
