STORAGE TANK SIZING
STORAGE TANK SIZING
PLZ, HOW TO ESTIMATE THE SIZE FOR A STORAGE TANK RECEIVING RAW WATER FROM A DEEP WELL PUMP AND DISCHARGES THE WATER TO SAND FILTERS AND THEN FILLING TWO TANKS FOR FLUSH WATER AND IRRIGATION.
MOREOVER, HOW TO ESTIMATE THE SIZE FOR IRRIGATION TANK ?
RE: STORAGE TANK SIZING
Please don't write in CAPITALS and not red either. It's interpreted as shouting. Next time I won't respond.
Size is dependant on why it's there. Is it they are just to be used a buffer between in and outflow? Is it there to provide storage for the irrigation of the deep well pump stops?
Could be any size from 1 m3 to 10000. Need to provide some more information about flow rates and how it is planned to operate.
and the sequence is the deep well pump will fill the raw water tank and stopped then the sand filter will draw water from the raw water tank and supply water to two separate tanks ( irrigation + flush water ) .
Also you probably don't want to be starting and stopping your deep well more than say 5 times an hour.
Can your deep well pump run for long periods or is it limited to a certain time / volume before it runs dry?
Is the outflow a constant rate or variable?
Lots of things go into making your decision.
The key for your irrigation tank is simply how long a period do you want / need to store water before you can get more water whilst still flowing out. 5 minutes? 5 hours, 5 days??
First work out some of this items in a design basis then make sure everyone is happy with that then do your sizing work.
