custom menu's are opening up help menu as well.
I have made a few autocad menu's in R14 and we have just moved them over to 2002.
My problem is that the menu's are slide based, and some times when I open them, they through up the help menu, as well as my custom menu.
Any ideas in how to fix my problem and or what may be causing it???
cheers,
RE: custom menu's are opening up help menu as well.
Maybe not without seeing the code, but it may be based on the actual position of the menu. i.e. The nth menu to the right may be set in your code?
