ask for "Is NX part checked out" in nxopen....
Hi -
I had been looking in the NET APi Reference for some call's to be used for information about if a certain nx part is checked out or not, when running nx11 in managed mode...
I couldnt find anything - but will just ask some of you guys, if you are aware about a method...
I need this information (checked out or checked in) in a small journal i am authoring these days....
a workaround could be:
Do some ITK stuff in temacenter config , and then from the nx side use the call UF_UGMGR_invoke_pdm_server
lklo
