Milling time in CS
Milling time in CS
Milling time in CS
I'm looking to come up with a machining time estimate to mill some CS Plate (A516-70). I need to face/shoulder mill off a "1/4 moon" shape of about 104 sq. in. by 1" deep. The only shoulder milling is around a 5" radius for about 270 degrees. The rest is all face mill. If it make it easier for estimating, it the equivalent to a diameter of 11.5" fully milled down 1". This would be done on an Okuma Milliac 561V, I'm not sure of the cutter type but I think it's Sandvik Coromill 390, exact tooling is unknown. I'm not looking for an exact time, just one that will let me know if someone is blowing smoke. Thanks much.
RE: Milling time in CS
Sandvik can probably give you a Metal Removal Rate in volume per unit time for a given insert cutting a given alloy, or at least starting parameters.
Mike Halloran
Pembroke Pines, FL, USA
Thanks, I'll give that a try
Hmmmn. Show a sketch of the "half-moon" - and pay particular attention to the corner details and fillets and edges. You may find you'll spend a significant amount of time lost trying to do "the last 5%" of the job. Or, by getting a cutter and insert with the proper radius in the first tool, you'll see that extra time vanish.
Thanks - I used Mike's suggestion and talked to Sandvik. We have to get a new tool and inserts but the time is down to 16 minutes!
