CMU Stair Step Cracking
Looked at a garage that had an area on the corner with your typical stair step cracking along the mortar lines (crack is about 0.25" wide) that would typically suggest foundation settlement/movements. Also in this same garage a tree fell through the roof (OSB & wood trusses) and left about a 4'x4' whole in the roof. This was caused by high winds from the recent hurricanes and the owner said he had a tornado go over his garage as well. Questions is do you think its probable that having a whole in your roof during a storm event would increase the internal pressures to cause the stair step cracking I am seeing? The wall is still fairly plumb; there was one horizontal crack along the same wall but it was very small compared to the cracking at the corner. I can see daylight through the walls in the areas with the larger cracks as well and I dont believe this garage has any vertical reinforcement.
RE: CMU Stair Step Cracking
