Is there a scalable third angle projection symbol in NX?
Good morning,
I need to put a third angle projection symbol in my title block. However, the user defined symbol doesn't change size when you adjust the text font size. Is there a symbol in NX 11 that is scalable, or do I need to create a new custom symbol to do it?
Thanks!
Al
Thanks!
Al
RE: Is there a scalable third angle projection symbol in NX?
I don't think that it's possible to scale objects in title block (custom symbol, picture). I have similar problem in 8.5, when I wanted add company logo to title block. I had to manually change resolution to fit predicted place, because when it was too big I received [#] or ##### etc. When I increased rectangle to achieve picture resolution, then it shown up. I also have similar problem with custom symbol in title block. You have to manually change size of custom symbol, or You have come to terms with that it won't scale. There is a second option to achieve projection angle, You have to write this to title block:
<W@$SH_SHEET_PROJECTION_ANGLE>
With best regards
Michael
