Generator voltages
Generator voltages
hi
a friend asked me a question:
In the generator test, the voltage between phase and zero was measured
400,400,230
What could be the problem?
thanks
400,400,230
thanks
RE: Generator voltages
It could be in the generator terminal box.
Rompicherla Raghunath
A-B = 400 Volts
A-C = 400 Volts
A-N = 230 Volts.
The tester inadvertently interchanged one phase and the wye point when testing.
Instead of testing from neutral to A, B, and C he tested from A to B, C, and neutral.
Bill
"Why not the best?"
Jimmy Carter
Further to the question I asked:
Regarding to the attach drawing if I change the connection between points 9 and 12 this mean the star point (4,8,9)
What tensions will I measure between the phases and and neutral
L1-N
L2-N
L3-N
thanks
Se my previous post.
To see 400 Volts you are measuring phase to phase. A-B, and A-C. To see 400 Volts from two 230 Volt windings the phase angles are correct.
Your friend had one phase interchanged with the neutral when he took his measurement.
Bill
"Why not the best?"
Jimmy Carter
