Midspan span load under Elastic Deflection
I have a beam fixed at both ends with tubular cross section, length 10m, yield strength 250Mpa, Dia 250mm, Wall thickness 5mm. I want to find the value of point load at centre for is elastic limit. Elastic Deflection will be Wl3/192EI and strain limit is 0.2% but how to find the maximum load at which the deflection is within elasticity of beam?
RE: Midspan span load under Elastic Deflection
sigmayield = Momentmax * y/Inertia
that is
250 = (W*L/8)*125/Inertia
