Pipe/Tank insulation jacket thickness
What is the normal thickness of pipe and tank insulation jacketing material? The two jacketing materials are PVC and stainless steel.
aumechengr
RE: Pipe/Tank insulation jacket thickness
http://www.naima.org/updates/doe.html has some information if you don't have a specific set of specifications for this job.
Also, companies like Thermon have standard recommendations for insulation thickness.
Note: this program is for fiberglass & mineral wool type insulation due to its sponsoring manufacturers. If you don't have high temperature requirements, foam insulations have lower conductivity and are less likely to have problem with condensation than open or porous materials such as fiberglass & mineral wool. Although, not fire-resistant.
For insulating chilled lines, styrofoam type is best.
http://www.dow.com/styrofoam/
If you only need to go up to 300 F, I think polyisocyanurate is best. I have no connection with Dow, but have used their Trymer rigd foam insulation in a metal finishing plant: "Trymer polyisocyanurate pipe insulation, a CFC-free, polyurethane-modified polyisocyanurate rigid foam insulation, offers a temperature range from —297°F to 300°F, excellent chemical and solvent resistance, and excellent resistance to both moisture and damage."
http://www.dow.com/styrofoam/na/dowpipe/prod/trymer.htm
This is thermal service (not for noise control).
Taken as a minimum requirement, 0.25 mm thickness should be o.k. for stainless steel jacketing.
Local standards or client's specifications may require higher values.
e.g.
German Standard DIN 4140 requires 0.5mm to 0.8mm minimum thickness in relation to the insulation circumference;
NORSOK standard R-004 requires 0.5mm to 0.7mm in relation to the pipe diameter;
Some Industry Practices (e.g. EXXON) require 0.25mm minimum thickness with thermal insulation, and 0,40mm with noise or noise&thermal insulation.
A minimum thickness for plastic jacketing is not available to me.
