Superflat concrete in walled room.
I need to place a very flat concrete slab to be polished, but it must be placed in a room with 4 concrete walls, placed up to the wall edges to ultimately be polished to the wall edges.
We always used formwork to set levels, screed and tamp, but if it must be flush with concrete walls how can we screed and tamp?
Slab Thickness: 150 mm (6 inches).
Area: 8m x 12m (26 ft x 40 ft) rectangular room.
Great thanks for any advice!
RE: Superflat concrete in walled room.
Place and polish slab.
Replace walls.
Details are just logistics.
Mike Halloran
Pembroke Pines, FL, USA
should have added... I like Mike's solution... it's doable...
Dik
MotorCity's idea won't solve your problem, and will just lead to cracking of the thin perimeter section.
Dik
