Question about hydraulic calculation of flexible pipes
This is general question. How do you guys claculate the pressure loss through a flexible pipe supplying a sprinkler? From the manufacturer's data I see one column with the actual pipe length and one with the equivalent based on 1" S40. So assuming I have my piping system made of S40, do I need to simply add these two values or just ignore the actual length and carry only the eq. length into the calcs?
RE: Question about hydraulic calculation of flexible pipes
Travis Mack
MFP Design, LLC
www.mfpdesign.com
"Follow" us at https://www.facebook.com/pages/MFP-Design-LLC/9221...
Also, Verify if FM is involved as you can see higher values in their column...
R/
Matt
We may assume just the one in design. The plumbers, hvac, and electrical folks make it quite another in the field..
R/
Matt
Travis Mack
MFP Design, LLC
www.mfpdesign.com
