Calculating Rigidity of a diaphram
Hello (this is my first post :) )
I am designing a structure with a cantilevered diaphragm. The shear walls are CMU walls, and the roof is plywood over 4x T&G.
How do I go about checking to see if the roof diaphragm is rigid or semi-rigid?
RE: Calculating Rigidity of a diaphram
