FEM Analysis of Pipe Support
Hi
I'm rather new to world of FEM, that's why I would like to ask someone experienced enough to help me with my problem. I'm trying to run static analysis of pipe support (see attachment) in Solidworks Simulation but I have doubts on how to setup the model, the boundary conditions i.e. fixtures and the how to transfer the load from pipe to pipe support. For ease of modelling this problem let's assume that this support is an anchor.
Any help is appreciated.
RE: FEM Analysis of Pipe Support
He or she will do it by hand calculation :)
best regards
Klaus
You can upload your IGES or STL file to the SimScale platform (www.simscale.com) and try the simulation there. They use Code_Aster and the GUI should help you get the results pretty fast. Willing to help you there if you like.
Cloud-based simulation in your browser:
https://www.simscale.com/
If you know how to do this by hand, please share this information with us, I'm alway eager to learn something new.
Hi @gravityandinertia
I'm trying to calculate allowable loads for pipe support.
PG4-LISEGA-Standard-Supports-2020.pdf
This in-depth engineering simulation analysis is typically needed for piping that experiences high-temperature fluctuations, or for extremely long pipe runs such as hot piping to coolers or headers.
Specific Cases, where equipment is sensitive to exposure to external force loadings, may also require the professional advice of a pipe stress analysis consultant.
Daniel Tan
BroadTech Engineering Pte Ltd
Your Trusted Engineering Simulation Consultancy
https://broadtechengineering.com
During the FEA analysis of the piping support, it is important that you take careful consideration of the following:
1D BEAM elements
– quick and easy, precise and accurate FEA simulation results for obtaining the magnitude of reaction forces and moments. This can be used in manual hand calculations for mechanical welds and serve as a useful guidance for the selection of pipe support materials
Detailed 3D / 2D sub models
- for Y-pipe section and diverters may be analyzed using the 1D BEAM model results.
Daniel Tan
Your Trusted Engineering Simulation Expert
https://broadtechengineering.com/cfd-simulation/
