SAW vs ERW pipe
SAW vs ERW pipe
I have to specify a material equivalent to the ASTM A672 C70 but produced in SAW rather than ERW. Which ASTM can I use?
Moreover wich is the thickness limit for the ERW process? Is it possible to use ERW for thickness above 30mm.
RE: SAW vs ERW pipe
RE: SAW vs ERW pipe
The only one that I found is the ASTM A 333 Gr.6, even though is a low temperature Carbon Steel.
RE: SAW vs ERW pipe
