reinforcing the edge of a concrete slab
I understand that its mandatory to reinforce the end of a free edge of a slab (balcony) with "U" shaped rebars. (image A)
But what in a case that a free edge of a slab ends with a beam (image B1 and B2). Since beam has shear reinforcement, is it really necessary to add "U" shaped rebars as shown in image B2 or is OK to do it as its shown in image B1?
Another example is when there is a horizontal tie at the odge of a slab (image C - bearing masonry wall bellow). There is no need in my opinion to add "U" shaped rebars since shear reinforcement of horizontal ties can also have this function.
I have seen different things in field (Europe). How do you do it and why?
RE: reinforcing the edge of a concrete slab
Dik
