Edge matrix selection with using wires
I currently have a hollow cylinder, and need to loft to a middle of it. There is no edge to choose as a loft selection. When I create a wire that is the same as the inner diameter, I do not see it in the GUI. I checked before and after creating it, and my edges matrix does not change length. Is using a wire the right way to go about making a new edge where I need it to be? my edge matrix does not change length when i create the wire.
br,
brandon
br,
brandon
