Multi cable transit (MCT) system
Does NEC/Saudi Aramco permits the passing of both the power and control/Instrumentation cables through the same MCT?
RE: Multi cable transit (MCT) system
Not sure, but why would anyone want to do something so counter productive anyway?
Keith Cress
It's permissible in maritime applications and per the NEC, but with Saudi Aramco, who knows?
The MCT system it is a kind of fire stop using plugs of chloroprene [neoprene] fitted on a cable diameter and introduced in a metallic frame. Usually it is mounted on a wall opening where a channel continues from a side to another of the wall. The cable could be supported by a cable tray or running directly on the channel floor.
NEC permits cable of 1000 V or less to occupy the same cable raceway if the insulation is the same.[see art.300.3] So control cable could occupy the same raceway with power cables[usually]. Instrument cable only as permitted on 725 and 727 articles. See-for instance:
https://www.hawke-hts.com/en/technical-information...
http://www.emersonindustrial.com/en-US/egselectric...
