Add watermark in drawing (not pdf)
Link
Version : NX10; NX11.
I would like to add a watermark to some drawings.
The proposed solution by JohnRBaker it could be a workaround.
However, you cannot control the translucency or which layer is above or below.
Any other idea?
Thanks in advance,
Airin
NX Designer
RE: Add watermark in drawing (not pdf)
What output format are we speaking about on this , since PDF isn't the case ?
Translucency does not exist in NX11 drawings. Neither the "in front of/ behind of" definition from MS/PowerPoint and other.
Custom Symbol ?
Tomas
Table so it can be drag-n-drop, with very thin text?
-Dave
NX 9, Teamcenter 10
