wear resistant steel?
Dear all
would you please help me to choose a wear resistant steel, which is not expensive and able to machining with cnc milling or wire cutting machines .
thanks in advanced
thanks in advanced
RE: wear resistant steel?
Dik
If other wear mechanisms are involved there may be better options.
More information = better answers
"Irons and steels for erosive wear applications - Firstly it should be noted that mild steel has reasonable performance for erosive wear, Hardening of the steel, as in several proprietary branded materials makes little or no difference in this application and there are no recommended materials . In order to improve the erosion resistance it is necessary to incorporate hard carbides."
Dik
