Jumbo HSS Availability
I'm working on a project where Jumbo HSS might be used. However I've been struggling to find any availability. Have any of you had any experience with these sizes? HSS12x12x3/4 specifically.
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: Jumbo HSS Availability
http://files.engineering.com/getfile.aspx?folder=3...
www.SlideRuleEra.net
www.VacuumTubeEra.net
https://www.aisc.org/steelavailability/search-resu...
the only supplier is Atlas Tube.
According to Atlas Tube's rolling schedule:
http://www.atlastube.com/images/hss/HSS-Availabili...
HSS12x12x3/4 are only rolled to order and you must contact them first.
It's the b/t<13.8 ratio for highly ductile elements unfortunately. We'd just use 14x14x1/2 if it weren't for that.
Thanks everyone! Contacting Atlas it is.
Single story 35' tall special truss moment frame columns in orthogonal directions (column occurs at the intersection of two stmf frames). AISC 341-10 didn't require the columns to be highly ductile, but AISC 341-16 does unfortunately.
