how to remove ANSYS Workbench lock when running in command line (batch)
I am trying to run a project in ANSYS workbench 18.1 in command line (batch), and I've got an error regarding ANSYS LOCK. It says that the project is locked.
I tried to add an environment variable in windows (ANSYS_LOCK OFF), but it did not work out. So I would like to know where is the ansys configuration file where I can edit/remove the ANSYS LOCK. Or if there is another way of solving this problem, it is 100% welcome.
Any help appreciated,
Best regards,
AndradeSilva
Best regards,
AndradeSilva
RE: how to remove ANSYS Workbench lock when running in command line (batch)
Rick Fischer
Principal Engineer
Argonne National Laboratory
Thanks for your reply.
I've already tried to delete the .lock file. The problem is that when I try to run a wb project in command line, the lock file appears again and blocks the project run. Do you know how to prevent the .lock file from appearing?
Best regards,
AndradeSilva
