Headloss of a static mixer
Hello all, at a wastewater treatment plant a static mixer will be used to mix a thin suspension (~1m³/h, <2% solids) into the wastewater stream (~300m³/h). If possible I want to know the magnitude of the headloss of my mixer. 100mbar? 1 bar? 5?
DN350 pipe.
I don't yet have hard numbers for the mixing quality required, since the mixer is upstream of a stirred tank I don't think I need to achieve a very high quality (whatever that means). My thinking is that a huge determining factor (alongside final quality) will be the ratio between the two flows.
In mixing (basically) water into water, a helical mixer is used - correct?
Edit to add:
Perry states that headloss of static mixers is usually given as a factor K, ration between headloss mixer and headloss empty pipe. K is between 6 and "several hundred". At my flowrates, headloss of 1m pipe is ~0.2 mbar I would expect single digit mbar headloss for my mixer - correct?
DN350 pipe.
Edit to add:
RE: Headloss of a static mixer
The headloss of the mixer will be dependent upon the amount of mixing the device is intended to impart and is normally carefully designed based on pipe size , flow velocity and the mixing energy required. A static mixer supplier should be able to give you some detail on this.
Ashtree
"Any water can be made potable if you filter it through enough money"
Ashtree
Re. solids, the whole affair is downstream of filter.
Ashtree
http://www.admix.com/pdfs/admixer-tech102.pdf
