Assembly Constraints for Pin in a Slot
thread561-336586: constraining to a slot so the part can move between centers of the slot
There are many old threads out there asking if this can be done and I'm hoping that since 2014 NX has hopefully added this feature in some way but I'm coming up empty. I don't have license access but would this be something available in the Motion Application?
I'm currently using NX 11 Mach 1 Design and Simcenter Structures.
RE: Assembly Constraints for Pin in a Slot
Datum Planes Datum Planes
This can be done in NX11 using a distance Constraint - you can set a range for the Distance from Max to Min
Look at
https://www.youtube.com/watch?v=s-pjsrPPWUU
at 13:10
John Joyce
Manufacturing Engineer
Senior Aerospace CT
NX 10 & 11.0.1 Vericut 8.0.3
Thanks @joycejo! That's exactly what I needed!
Here's an "NX Quick-Tip" video which explicitly covers the use of the "Driven Assembly Constraint".
https://www.youtube.com/watch?v=FAPTpV6G5Wo&in...
John R. Baker, P.E. (ret)
EX-Product 'Evangelist'
Irvine, CA
Siemens PLM:
UG/NX Museum:
