Blue Screen of Death During NX Updates (MR, MP Patches)
We are having an issue with our workstations crashing, Blue Screen during NX 11 updates. We have contacted GTAC, they mention a possible Driver issue. We are running HP z230 workstations. I am tossing this out here, to see if any one else has had this issue? All of our components are certified. Any help or a good way to diagnose this would be great.
RE: Blue Screen of Death During NX Updates (MR, MP Patches)
Are you installing and updating as Administrator? (Right click-Run as Administrator)
Ronald van den Broek
Senior Application Engineer
Winterthur Gas & Diesel Ltd
NX9 / TC10.1.2
Building new PLM environment from Scratch using NX11 / TC11
By "during NX 11 updates", do you mean when you change parameters of features and NX attempts to update the model or "NX 11 updates" as in applying a patch (MR or MP) to NX 11 itself?
When NX crashes unexpectedly, the first place to look is in your log file. Check the most recent *.syslog file in your temporary directory (it is a plain text file); scroll to the bottom and see if there are any error messages there. Even if there are no obvious error messages, the last few actions taken before the crash may provide some insight. Note that there is no NX log file created during the patching process; the installer may create some sort of log file of its own, but I'm not sure about that.
www.nxjournaling.com
- do you use the .bat file or the .exe ?
I always, since i always have multiple versions of NX installed, start the version-corresponding command prompt, and then in that window run the "ugs_update.bat"
This way I am quite certain that the files are copied to the correct directory.
( i have been doing this for some years by now, the updates of today might have protection against this problem.)
Tomas
Thanks for feedback.
