opening of solenoid valve while engine is off
If the injector solenoid opens somehow while the engine is off, what will happen? Will the diesel fuel be admitted to the cylinder in the absence of required compression ratio or some protection will prevent this from happening? How can the fuel be removed from the cylinders if this happens in any case?
RE: opening of solenoid valve while engine is off
You will have to be more specific to get a more precise answer.
There might be one teeny tiny meaningless squirt of fuel the first instance of opening the first injector due to residual rail pressure if the engine has not been stopped for long enough for the rail pressure to bleed down (which should take on the order of seconds after shutdown). This is of no consequence whatsoever.
PJGD
