On load tapchangers - US v Others
The US tends to use reactors in their tap changer diverter configurations, whereas a large part of the rest of the world uses switched resistors. As a non-US electrician, what are the benefits and drawbacks of using reactors, and is this as a result of the common US practice to tap on the low voltage side of the transformer, against the neutral end of the high voltage side in other parts of the world. What is the typical maintenance program for the reactor version?
RE: On load tapchangers - US v Others
Laughton, M.A.; Warne, D.F.: "Electrical Engineer's Reference Book", 16th edition, Oxford, 2003
US engineers tend to specify a large number of taps with small tap steps. With the inductor approach the bridging position can be used as running tap.
