Fusion 360 Sheetmetal fill gaps and unfold
Good afternoon.
See attached image.
I need to unfold my sheet metal model; however, there are gaps between the plates (as shown in the attached image). What is the best way to fill these gaps and then determine a 2D sketch which I may use to assemble the model.
For more clarity, I'm attempting to make a model in CAD, then unfold it so that I may cut wood boards and and assemble them to make what is represented in the CAD model.
See attached image.
RE: Fusion 360 Sheetmetal fill gaps and unfold
And I can't quite guess what you're working on when your question combines "sheet metal" and "wood boards"...
Is this a laser-cut thin sheet of wood veneer with a "grid" of slits that allows the wood to flex? Like the image (found at random) below?
If so, I doubt Inventor can unfold it for you with the slits in the folded model.
STF
