Wrapping tape for DI pipes - corrosion protection
Dears ,
we have one project and they need wrapping tape . the material we have is Butelyen PE/RUBBER with 0.8 mm thickness , but the specs of the project is called fro PVC Butmen type thickness 1.1 mm ! So how can i approach the client to approve my tape and from your point of view which type is better fro pipe corrosion .
Ahmad
Ahmad
RE: Wrapping tape for DI pipes - corrosion protection
Ashtree
"Any water can be made potable if you filter it through enough money"
https://www.dipra.org/ductile-iron-pipe/dipra-fact...
