Fitting Tag in Isometric
hello
What is tag "F10 B12 G13" with an arrow which indicates to a fitting in isometric drawing.
what is the definition of each part of tag?
thank you
RE: Fitting Tag in Isometric
Have a look at the parts list on the isometric.
I am only guessing but pretty sure it will be Flange, Bolts, Gasket,
Cheers,
Shane
mmbguide,
It may relate to the individual material items. I suggest you look in the "BOM" (Bill Of Material) and see if there is an answer there.
Sometimes its possible to do all the right things and still get bad results
It's the Isogen call-out for flange, bolts and gaskets for a flange assembly, usually contained in a rectangle rather than as individual circles. As pennpiper says, look at the bill of materials.
The tag refers to flange, bolt, and gasket. The numbers correlate to the number in the bill of material (BOM). You can find the specifications (quantity, description, size) for each item in the BOM.
Thank you all
