Why diode with lamp ?
The rear roof light in grandsons car has a diode connected in series with a 10watt filament lamp. As the is a 12 dc circuit I’m at a loss to see what duty this diode has. It is clearly forword biased as the lamp works, reversed bias = no light.
Can someone offer an explanation please.
RE: Why diode with lamp ?
I have also seen diodes used on bulbs when there was a dimmer circuit used to dim dashboard indicators that were also connected to switches to activate devices and options. Again, the diode makes it possible for proper operation of the bulbs and also allows for the dimmer circuit to control brightness properly.
Oh and it will last 2.2 times longer.
But, I agree with Com, it's likely for some logic function preventing back feeding. I had to add diodes for an alarm system that detected door openings using the domelight switches.
Keith Cress
The car is a current VW Golf. The diode is an original item being crimped into the plated steel lamp fixings. The light is in fact the boot/ trunk light mounted in the rear roof trim and illuminates above the parcel shelf. There is a requirement to add additional leds below shelf.
The existing light would seem to be controlled by a simple micro switch actuated by 5th door/ boot/ trunk.
The existence of the diode is just a curiously point. Switched +ve connected to diode connected to filament lamp connected to solid -ve. While all comments are valid none seem to be a good reason for VW to throw in a diode ??
Chances are, the hatch switch is an input to a lighting module and the lighting module controls that lamp. Among other things, this allows the electronics to turn off the interior lighting after a period of time with the hatch open in order to avoid killing the battery.
It still doesn't explain the diode, but it may have something to do with someone wanting to fine-tune the brightness of the lamp, and opted for a diode for a calibrated voltage drop.
Nothing on a current-tech VW is controlled by a simple mechanical switch turning current on and off- everything is run through ECMs of various types.
I can't speak for every other manufacturer- I own 2 modern Volkswagens and have been elbow-deep in both of them many times, but I would assume everyone else is using similar architecture.
