ANSI Flange 300# Failing at Design Pressure
Hello Friends,
We are designing Propane Mounded Storage Tank for Water Capacity of 119,000 Liters. Here are the following details with the SS.
Working Pressure - 12 kg/cm^2 (171 psi)
Design Pressure - 21.356 kg/cm^2 (304 psi)
Corrosion Allowance - 1.5 mm (Is it fair to have 1.5 mm (0.059") or should we go for 3 mm (0.11")as it is ?)
Temperature - (-)42 deg C (-41.11 deg F) to (+) 55 deg C (131 deg F)
Density of Propane - 0.441 kg/m3 (0.02753lb/ft3)
for more details pls see the attachment
My query is, how come the nozzle is failing for 300# and passing for 150# ? Nozzle is failing at MAWP. MAWP is 22.33 kg/cm2 (317psi)
Your kind response will be highly appreciated.
RE: ANSI Flange 300# Failing at Design Pressure
If failing on reinforcement perhaps static head is the cause? You are going to need to carefully check your inputs & outputs, IMO.
Cannot offer any opinion about the CA, what is industry practice for the class of work?
Mike
1) What is the "SS" ??
2) My experience has been that nearly all propane tanks in the USA are designed to a MAWP of 250 psig. Why are you designing to a much higher pressure ? (Because the client said so is not an acceptable response)
3) A corrosion allowance of 1.0 - 1.5 mm is a common choice for propane service. (Check the vendors of these tanks on the internet) IMHO 3 mm is excessive
MJCronin
Sr. Process Engineer
But as others have indicated, the flange rating is only one aspect of getting the nozzle with flange to pass the design requirements. It's likely that there is insufficient reinforcement as per UG-37, etc, to support the design pressure. You'll have to review the calculations for this and for any other insufficiencies.
But if nothing changes but it works when you put in class 150, then I don't know. Maybe weight of the flange and blind exceeds some stress value on the nozzle pipe itself? a 20" class 300 WN flange and blind is quite a lot of weight.
So try a thicker nozzle and see if it goes away.
One thought, do you have the software designing nozzle reinforcement for the vessel MAWP? If so, could the 150# flange be limiting the MAWP of the vessel such that the opening reinforcement passes? But when you put in a 300# flange the vessel MAWP increases and the nozzle now fails?
As I said, just a guess.
Thank you very much for all your replies. The problem got solved. I have increased the thickness considerably with approval and things are now fine. Thank you once again.
@MJCronin SS --> Screen Shot
BTW MJCronin, why in America do you take particularly 250 psi ? is there any reason for that?..Regards
Assuming that the nozzle and opening were designed for the same pressure in both cases (which isn't necessarily so, with software options) then the issue is likely that due to the longer hub length of the Class 300 flange the projection of the nozzle neck was decreased sufficiently (assuming that the projection to the face of the flange was identical in both cases) so that the reinforcing area A2 in the nozzle neck was reduced such that the total reinforcing area was insufficient. This would result from ASME Code UG-40(e) stating that material within the flange hub cannot be utilized as reinforcing area.
You never bothered to answer my question, but yet you demand more information from me ....
You state that your application is for "mounded storage" and that your vessel MAWP is 317 psig.
The vapor pressure for propane at 100F is approximately 172 psig. Your mounded design will never reach 100F
Again, in my opinion, a MAWP of 317 PSIG is too conservative ...
In the US, the NFPA organization makes a distinction between propane storage acting as vehicle engine fuel containers (subject to shock and overpressurization) and those acting for space heating and the like. Pressure vessels for engine service shall be designed to 312 psig, others to 250 psig
http://www.nfpa.org/Assets/files/AboutTheCodes/58/...
Additionally, the 250 psig standardization for propane pressure vessels means that ASME vessel shops can fabricate a whole range of products on spec, and compete in the marketplace for both propane and anhydrous ammonia vessels.
https://hansontank.com/ammoniatanks.html
MJCronin
Yeah, I knew you had said that. I thought, perhaps, you might have discovered why.
Mike
I am sorry for the delay.
I really appreciate your answer for the same it has however increased my knowledge. The reason that it was failing because it was not sustaining on that thickness. hence 300# flange was failing and 150# was passing. That is all i can say.
BTW, i am not demanding to answer i was just curious to know why US has specifically design consideration for 250 psig. Peace
