URGENT HELP- COLUMN LAYOUT
Dear All,
I am a starting engineer and I wanted your views on the column layout. Basically, it is a one storied house and I wanted your advice for the layout of column. These are the few facts on the building, the external wall and partition wall are 200 mm and 100 mm brick masonry wall respectively. The owner has asked me to check 2 options which are as follows:
1. Option A : With only single storied what will be the cost.
2. Option B: With G+1 what will be the cost.( For this I am planning to provide 250 x 250 mm column)
I just wanted your views on the layout of the column for the options given. The arrangement of rooms will be same as the ground floor and the stair case will be provided outside. So you may kindly leave the staircase.
For that I am attaching a autocad screenshot. Your help will be highly appreciated.
KARMA
RE: URGENT HELP- COLUMN LAYOUT
Lots of questions.
Dik
Dik
For the second floor, the maximum span is 5.9 m, so TJI would likely be selected to clear span. Columns would be either built up studs or Parallam and would be situated in the walls.
BA
I general, vertical structure is cheap compared to horizontal structure. So I'd seek to minimize slab depth and then introduce as many columns as are necessary to make that that slab depth possible. From what I've seen of these structures, you'll be targeting a slab depth of 125-150 mm.
Dik
