DETAILING REINFORCED CONCRETE COLUMNS IN TENSION
Hi guys,
Any tips on how to detail columns in tension? Any reference materials?
RE: DETAILING REINFORCED CONCRETE COLUMNS IN TENSION
- Pretty sure that ACI prohibits lap splicing for this condition. Gotta go couplers etc.
- Keep an eye on the detailing at the connections to whatever you're connecting to at the member ends. Usually this makes for somewhat painful shear/punching shear considerations.
- I'd recommend running a calc on expected crack width, particularly if the columns will be exposed or in a corrosive environment.
Also, the shear capacity of tension members is reduced based on the ratio for the load to the gross area of the member. ACI 318-11 Eq 11-8.
