How to calculate built up back pressure?
How to calculate built up back pressure when hot water relieves and flashes into steam in the discharge piping?
Relief Valve is 1/2"x3/4" with a set pressure of 1000 psig. The water temperature is 107°C.
RE: How to calculate built up back pressure?
for a short tailpipe terminated to atmosphere one may presume critical flow (or calculate fluid speed / pressure drop) but considering the small size of the PSV probably that is not required,
for flashing liquids there are different models, see for example
https://www.cheresources.com/invision/topic/21654-...
but, as said, probably that is not required in this case.
at 107 C you are close to saturation line (atm) and considering the dt across PSV and piping possibly it's liquid (to verify)
