Modify hinge display position SAP2000
Hello everyone!
I was wondering if someone knows how to modify the position in which hinges are displayed in the deformed shape of a model while moving throughout the steps defined. The problem I am facing is that I assigned hinges in the relative positions 0 and 1 of columns and beams, so when hinges are displayed I have to zoom deeply in each node to see where are the hinges because it can be distinguished if they are in the column or beam (I attached a photo of how it looks). I tried using the "object shrink toggle button" but it does not make any difference. Hope someone could help me out.
Thank you in advance!!
