Frac Composite Plug Operations
I heard about Frac Plugs that are RIH make up with the guns assembly. But what I dont know if the fracking operation involve run a frac assembly and the Casign ID will be subjected to withstand fracking pressure? As an example, the customer expects to frac the well with 15k but the casign ID cannot withstand that ammount of pressure, only reach 7500 psi (Burst) as handbook state.?
Thanks for your replies in advance. It will help me a lot
RE: Frac Composite Plug Operations
In all of the completions that I have seen, each tubular would need to be rated for at least as much pressure as is likely be encountered plus a safety factor.
Is you customer planning to treat down the casing or through another tubing string?
I have seen scenarios where you have 7" production casing and a 4-1/2" liner where the liner has a polished bore receptacle (PBR) liner hanger top. In this case a seal assembly stinger is run into the well on tubing and stabbed into the liner hanger. In this instance, the 7" production casing would likely not have to be rated to full treating pressure since it should not experience full treating pressure. Though, the liner, liner hanger, PBR, seal assembly, tubing, and wellhead components would need to be rated for expected treating pressure plus a safety factor.
