mirror a part in assembly
How to mirror a part in assembly? its identical and not an LH, RH type part. i used symmetry, but it creates new physical part and appears as separate part in BOM which i dont want.
RE: mirror a part in assembly
If it's just another instance of the same part; copy and paste the part back into the assembly, use the compass to mirror (rotate) it, and add assembly constraints to define the new instance position
