Bowing of Insulated Panels
Dear All,
Im calculating the bowing of an insulated wall panel according to PCI 7th ed. and the pci mentions that the temperature differential does not exceed 40 F in solid wall panels and does exceed in the insulated, does anyone have an idea on average temperature differential ? and when calculating the bowing should i discard the insulation thickness considering only the concrete thickness ?
