Modifiying tempered glass
I have some 4" OD tempered windows that I need to modify by .06", should I heat the glass and then modify or is there another way. If so, what temperature.
thanks in advance.
Mark
thanks in advance.
Mark
RE: Modifiying tempered glass
A toughned glass modification is tough job.Try to cut it and it would braek off. Try grinding ,it would go up in splinters.The only way you can do that is to heat up the glass gradually by sticking to a heatup curve (which depends on the composition of the glass) anneal it following the annaeling curve of that glass and then do the modification. Once done you would have to re toughen the glass by following a heat up curve and then quenching of the glass.
Why not try and modify the holder of that glass portion.That is easier.
Chatterjee
Tempered glass can be ground or polished as long as you do not go through the compressive layer that was generated during tempering. Without knowing to what degree your glass was tempered its tough to know how deep this is. I "think" .06 is a safe depth, but don't send me the bill if it breaks.
