3 PWHT Cycles for test coupon SA-516-60
Can plate Sa-516 Gr70 withstand 3PWHT cycles ( on other word will it pass ? )
Plate thickness : 14 mm
What about the simulation applied also for pipes - 106Gr B and flanges 105 ?
RE: 3 PWHT Cycles for test coupon SA-516-60
This is a requirement from client !
Can stockist do the test or it has to be from mill ? Also How I know theoretically that a certain material would probably withstand n number of cycles ?
Look at the actual strength stated on the MTR, depending on how far above the minimum required is your margin. For each PWHT cycle the strength can degrade slightly.
If you cannot go to mill for small quantity then what is the best to do?
