Sequential analysis in ABAQUS
Let me describe my problem which I'm trying to simulate.
1. I'm doing a dynamic analysis for 1sec with 1e-2 as an increment time with displacements as an output for some nodes.
2. Now I want to do another dynamic analysis for the same duration and increment, with the same model but now I want to import the results from the previous results such that it should take the time varying displacements obtained from first analysis.
Is it possible ?
Pranoy Nair
RE: Sequential analysis in ABAQUS
Why don't you use two steps in your analysis?
