Creo 2.0 Installation issue
Hi Folks,
Tried installing creo 2.0 M version on a windows 8.1 64 bit machine.Did run the patch SSQ and all files got patched without any issue.Replaced the host id on the license file prior to installation.But still getting the message "License error, host id incorrect ".
Details : creo 2.0 win 32 - 64 bit M version, windows 8.1 64 bit,Ssq patch M version.Anything else?
RE: Creo 2.0 Installation issue
If it is cracking the license files so you are running an illegal license, then you will get no help from here.
Ben Loosli
