Replace in kind and code to follow
Costumer is replacing a kind of an equipment. However, for assurance they would like to check the steel beams. The building is old two issues here:
1)The loads can be used the original design loads, right?
2)The AISC code to check the beams also can go to the original design time AISC (like AISC 9TH Edition)or the latest AISC 14 Edition needs to be used?
Thank you
Thank you
RE: Replace in kind and code to follow
Hope they are not too off tangent!!
Depending on the Jurisdiction though, they may require you to design for new loading depending on the scale of the modification.
Just how similar is the new equipment?
How do the beams perform under modern code requirements?
