Retained Austenite on 20MnCr5 material
Have a forging that gets machined, Carburized, Hardened and Temper, then machined some more on a few dimensions. The customer requirements are <25% retained austenite in the functional area's, They are evaluating this optically @ 500X to photo standards all the way to the very surface. Using a few ISO documents we have found that performing a Vickers microhardness @ .04mm from the surface, if that meets the minimum 58Hrc then the part is considered good. Customer is having difficulty recognizing this method. Any suggestions?
I suspect the only way to reduce the RA is to cryogenic (freeze) the parts to convert the RA to Martensite.
Thanks in advance.
Thanks in advance.
RE: Retained Austenite on 20MnCr5 material
Maui
Either less C or a longer diffusion step?
But to hit the hardness you may need to freeze them.
If the customer wants >58HRC and <25% RA then that is the spec.
Just looking to see if there is another way besides freezing.
With regards to ISO standards, these have nothing to do with acceptance criteria for RA, unless you are referring to ISO 6336-5, in which case Table 5 section 10.5 specifically limits RA to be 25% maximum for MQ & ME Quality.
If you are looking for a method to process existing parts to meet the 25% RA limit and don't want to use sub-zero treatment, shot peening is another possibility. Otherwise, you will need to work on the carburizing cycle: temperature, carbon potential, time, atmosphere (ammonia addition at the end of the cycle is commonly used to reduce RA).
Maui
The threaded area's are .1mm to .6mm the thickest area would be 1.3mm. As I stated we are bound by specification to .7% Carbon, so we Aim for .75 to ensure .7 min. We do have some carbides but we have adjusted for that and they are under the maximum. ISO 6336-5 was 1 document that uses the micro-hardness as a deciding factor at .5-1.0 mm from the surface. We are right in the mean for the Effective Case Depth so our time @ 1725F with a Carbon of .7 seems correct.
How do you apply ammonia at the end of the cycle and what does it do?
Thank you for the input and discussion.
Cool to 1475F @ .75C hold for .5 hrs Oil quench 150-200F. Wash then Temper 350F 2hrs.
Gas is from Endo Generator, Generator and furnace all controlled with Atmosphere Engineering Computer system software.
Customer spec. has a minimum .70 Carbon call out, simulated Carbon with a .75 set point is showing a .68Carbon for the simulation.
Effective case depth has been at the mean target, case hardness has been on the high side 58-63 and we see 64-65 on some parts.
I have attached a photo of the RA & Carbides, this was rated at 35% optically by the customer.
What suggestions to improve the current cycle parameters?
Sorry for the delay in responding, regular work has been busy the past week. Anyway, if I understand you correctly, you are saying that this part has a cross-section that is a maximum of 1.3 mm? That is extremely small for a carburized part. Most carburized parts are shafts or gears with a specified case depth of 0.5 to 1 mm, so if the entire part is only 1.3 mm thick, then the specified case depth must be quite small too, maybe 0.2-0.3 mm only? For parts this small, it will be extremely difficult to produce a case microstructure with < 25% RA using conventional gas carburizing. With low pressure (vacuum) carburizing, you can introduce the carbon very efficiently using pulsed acetylene, so very thin parts are often processed using this type of equipment.
Anyway, looking at your recipe, I think that your pre-heat cycle is part of the problem. A typical pre-heat at the process temperature would use a much lower CP of say 0.45% rather than 0.75%. Since the preheat is the longest part of your cycle, the parts will be absorbing carbon during this entire preheat sequence. Also, there is very little time for diffusion at the lower carbon potential (0.5 hours at 1475 F and CP = 0.75). This is compounded by the relatively low temperature of 1475 F, meaning that the diffusion rate is even slower, concentrating more of the carbon in the case and producing more RA. Typical temperature prior to quenching for 20MnCr5 is 1490-1545 F, so I would increase the temperature of that last stage. If you are concerned about distortion, I would increase the oil temperature and decrease the agitation rate. 150F is a very low oil temperature, and if this is a medium or fast oil, it will induce more distortion.
Best of luck, and let us know what happens going forward. By the way, I could not view the image, not sure if it is my work computer/IT settings, or something with the link.
