Save drawing CGM data
Hi everyone,
There is a parameter set in my NX11 where the option "Save drawing CGM data" is enabled.
Could someone tell me for what can I use the cgm? where is saving this file?
Thanks in advance,
Airin
NX Designer
RE: Save drawing CGM data
are you using Teamcenter or using Vis mock up? If so you can use this data to do an overlay compare of two different revision against each other to verify changes. I am sure there are other reasons, but this is what we mainly use it for.
We use it to generate (team-center Dispatcher) our PDF's in the Release process. It is much faster to create a pdf from a cgm than having to open the drawing in NX and generate it.
Ronald van den Broek
Senior Application Engineer
Winterthur Gas & Diesel Ltd
NX9 / TC10.1.2
Building new PLM environment from Scratch using NX11 / TC11
also, in the Teamcenter viewer, if you view a drawing, - it is the CGM data you are watching.
Tomas
Thanks to all.
We don´t use teamcenter or Vis Mock-up.
So I think it won´t be necessary.
Best regards,
Airin
NX Designer
There is also a "track changes" command in native NX that will compare the previous drawing to the current drawing. It saves some CGM data to do the comparisons, but I don't know if it is directly related to the "save CGM data" save option.
www.nxjournaling.com
Hello Cowski,
Yes, I thought the same, that it will be usefull to track changes. But I saved the drawing with this option enabled. After that, I tried to use the command "Track Drawing Overlay" and also "Visual Overlay", but the next message appears: "No snapshot data exists in the current drawing file. Select the Create Snapshot Data option to create snapshot data."
Therefore, I create the requested snapshot data. When I click "Create Overlay Data" I see in the Status Line: "Writing CGM"
I really don´t understand this option.3eyes
Airin
NX Designer
