Engineer of Record no longer employed with firm....
If the engineer who sealed project drawings is no longer employed with the company, and drawing revisions are made that require re-stamping, is it required that the original engineer (EOR) stamp the revisions or can another engineer stamp?
RE: Engineer of Record no longer employed with firm....
One fact to note is that many states now require the engineer of record to observe construction of the design - if that engineer is no longer with the company, they can't be the one to make those observations. I would recommend you confirm what the requirements are for the state you're performing work in and ensure you (and your company) are maintaining compliance with the law governing PE seals. In some cases, a simple notification on the change in engineer performing the observation is acceptable - in other cases, the new engineer of record will need to re-stamp the applicable drawings to go on record as officially performing the observation.
TTFN (ta ta for now)
I have inquires into several State Boards and will advise when I hear back.
Good to hear from you again!
Mike McCann, PE, SE (WA)
Which states? I'm not sure I've heard of this before. (I've certainly heard of inspection requirements.)
One such example is the state of Hawaii - currently working on a project there.
Interesting. Are we talking periodic site visits or out there throughout the process? The latter would be just about impossible for me. (I'm self-employed.)
""Observation of construction" means making and documenting visits to the site by a licensed engineer, architect, landscape architect, or qualified representatives working under the supervision of a licensed engineer, architect, or landscape architect, as the case may require, to observe the progress and quality of the executed work and to determine, in general, if the work is proceeding in accordance with the contract documents. It is not required that they make exhaustive or continuous on-site observations to check the quality or quantity of work nor is it intended that the engineer, architect, or landscape architect be responsible for construction means, methods, techniques, sequences, or procedures, or for safety precautions and programs in connection with the work."
No continuous presence required - additionally, as stated above, allowance is made for "qualified representatives" under the supervision of the PE to make the necessary construction observations, as well. No criteria is given for what makes someone qualified - so that responsibility seems to rest on the PE in charge of the observation.
The way we've approached it with our Hawaii work is to actually go out to job sites a little more often and generally be more available to contractor than seems to be the norm elsewhere to help address unforeseen or unique conditions, identify and mitigate deficiencies, etc. Instead of contractor feeling like they're out building on their own, we try to provide support so they actually ask questions and bring up issues instead of just winging it (though some are stubborn and still just wing it).
I think most engineers and contractors would agree that having EOR more involved during construction is probably beneficial, main issue is getting owners to buy in and actually pay for it. To avoid that issue, Hawaii takes it out of owners' hands and just requires it.
