MDMT Flat head
MDMT Flat head
Hi fellows, I'm performing a fitness for service (API 579 Part 3) on a Exchanger who works at low temperature. When I check the design data it has a minimum temperature of -10°C.
The flat head has a thickness of 209mm (SA-105). When I check the minimum temperature trough the toughness curves of ASME VIII, I found that the Minimum temperature is 18°C. I'm useing the curve "B" and the goverment thicknes as 209mm/4
There's some restriction to this kind of component?
RE: MDMT Flat head
RE: MDMT Flat head
Ehzin
RE: MDMT Flat head
